Enable / Disable Email Delivery From a Graphic
  • Enable / Disable Email Delivery From a Graphic
  • sesa116871
    sesa116871
‎2018-09-06 09:36 AM
Have the ability in SBO to disable and enable the email delivery from a graphic with a simple switch
Automation Server (AS), Enterprise Server (ES) - all versions
- none -
In order to enable / disable email delivery from a graphic, do the following:
1. Add a Switch component to a graphic. Save the graphic.
2. In Workstation, open the bindings window for the graphic. Bind the Status of the Email Notification to the Value of the Switch.
Tags (3)
  • 16046
  • smartstruxure
  • struxureware
