Editing TAC Xenta 280/300/401 that has the same XIF file
  • Editing TAC Xenta 280/300/401 that has the same XIF file
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 02:38 PM
  • Xenta Programmable Controllers
  • Xenta 280, 281, 282, 283, 300, 301, 302, 401, 401:B
  • Menta
  • NL220, LonMaker
The second method can cause a total mess in the LNS database regarding which Device Template the different devices then will belong to.
Tested both with LonMaker and NL220.
If you have several Xenta280/300/400 that has the same XIF file (which is a not an unusual scenario), and you want to edit a few of the MTA files, maybe regarding the SNVTs, then it is recommended to:
  1. Edit Device A, Download app and params Device A
  2. Edit Device B, Download app and params Device B
  3. Edit Device C, Download app and params Device C
  4. etc
and NOT:
  1. Edit Device A
  2. Edit Device B
  3. Edit Device C
  4. Download app and params Device A
  5. Download app and params Device B
  6. Download app and params Device C
  • 3395
