EcoStruxure Building Activate Flex Server is unable to synchronize time with RTC.
  • EcoStruxure Building Activate Flex Server is unable to synchronize time with RTC.
  • Mukesh_Sangwan
    Mukesh_Sangwan
Ensign Mukesh_Sangwan Ensign
‎2025-03-30 05:56 PM
on ‎2025-03-30 05:56 PM
There are issues for Flex Server to synchronize time with the Real Time Clock (RTC).
  • EcoStruxure Building Activate Partner Portal
The RTC parameter fails the synchronization test.
  1. Check the voltage of the coin cell using a multimeter.
    • If the voltage is less than 3.3V, replace the coin cell.
    • If the voltage is equal to or greater than 3.3V and the test still fails, report the issue to technical support.
  • MukeshSangwan25
