Easiest way to determine what is causing a point to be exported
  • Easiest way to determine what is causing a point to be exported
  • ScottLeedberg
    ScottLeedberg
  • Dave_Shore
    Dave_Shore
‎2018-09-06 02:51 PM
If I have a point that is flagged for Export what is the easiest way to determine what is causing it to be exported?
Cyberstation
Determine the cause of a point to be export.
The easiest method to determine what is causing a point to be exported is to send the site to an ASCII file from Continuum explorer. Then open the dump file and search the file for all occurrences of that point name. Review each occurrence to see if there is an alarm attached or a program in a different controller that references this point.
NOTE
This same method is the quickest method of finding various objects that may be reference by other objects as these are often not available in listview
eg. Objects referencing Alarm Enrollments, Event Notifications, Trigger points, Alarm Points, etc.
  • 2906
