EWS / Smart Connector Duplicate Hosted Objects and Binding Issues
  • EWS / Smart Connector Duplicate Hosted Objects and Binding Issues
Picard RobertAndriolo Picard
‎2025-06-11 10:23 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:31 AM
When hosting objects from EWS/Smart Connector, such as Security Expert, into EcoStruxure Building Operation (EBO), additional or mismatched object names can result in unresolved bindings and duplicate EWS IDs.
Common symptoms include:
- Duplicate EWS IDs with different names
- Unresolved or broken bindings
- Binding loss after deleting containers
Duplicate EWS IDs with different namesDuplicate EWS IDs with different namesDuplicate EWS IDs with different namesUnresolved or broken bindingsUnresolved or broken bindingsUnresolved or broken bindings
EcoStruxure Building Operation, EcoStruxure Security Expert.
  • EcoStruxure Building Operation Enterprise Server (ES)
  • Security Expert
  • Smart Connector Integration
  • EcoStruxure Web Service (EWS)
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
Typical reasons for this to occur:
  • Hosted object names do not match those in Security Expert.
  • Deleting containers without proper renaming can cause binding loss.
Best Practices for Future Hosting
  • Always rename the hosted object in EBO before rehosting from the hardware folder.
  • This ensures that existing bindings are preserved.
  • Avoid hosting the entire `SecurityExpertServer` container—only host changed or new objects.
For Unbound or Irrelevant Objects:
- If objects have no bindings, naming is not critical from an EBO perspective
- Delete the container and rehost the object from the **Hardware folder**.
To Retain Existing Bindings
  1. Identify the correct object name in the Hosted Containers folder
  2. Copy the name to avoid typos.
  3. Delete the duplicate object with the correct name.
  4. Rename the existing EWS ID to match the copied name.
  5. Save the rename
  6. Verify bindings:
    1. Right-click the renamed object
    2. Select Delete
    3. Click Show References
    4. Confirm bindings are still valid.
    5. Click No to cancel deletion.
  7. Repeat this process for each object (inputs, outputs, doors, etc.) that has existing bindings.
Labels (2)
  • EcoStruxure Security Expert
  • RobertAndriolo25
