ETHERNET Cable Requirements.
  • ETHERNET Cable Requirements.
  • DavidChild
    DavidChild
‎2018-09-07 08:01 PM
Sigma 4.05 and earlier versions.
V53 and ARM7 Processor Boards.
ETHERNET Network cabling advice.
The Sigma Cabling Guide should be followed when installing an ETHERNET network: Sigma Cabling Guide 2.2
Further information about cabling can be found in the following guides:
For V53 Processor Boards (UNC496, 596, UNC532, DNN and IC integration controllers): Cguide26.pdf
For ARM7 Processor Boards (UNC696, 796 & UNC632): Cguide31.pdf Cguide32.pdf
For ARM7 Processor Boards (DNN3 Decentralised Network Node): Cguide33.pdf
For ARM7 Processor Boards (IC3 Integration Controller): Cguide34.pdf
RJ45 Plug connections are:
  • Satchwell BAS & Sigma
  • 4468
