ES Database Size
  • ES Database Size
  • DavidChild
    DavidChild
  • Dave_Shore
    Dave_Shore
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
ES Database Size
‎2018-09-11 08:54 AM
ES Database has grown to several gigabyte
  • Building Operation Enterprise Central
ES Database size can grow quite large when the ES crashes often. Open Software Administrator and find the location of the ES db folder. Below are two screen shots of the Logs and Crash Information folders. As can be seen, these dump files can increase the size of the database.
Once the reason for the Enterprise Server crash is resolved, these files can be either be deleted or, preferably be moved to another storage/drive location.
If the ES/EC is still crashing, all the core dumps should be collected and sent to to your local support team for processing. Due to the size of the crash dumps, upload to BOX or similar and provide the link to the support team.
Tags (3)
  • 17720
  • DavidChild21
  • DavidShore21
100% helpful (1/1)
