EH Series Humidity Sensors – Specifications, Setup, and Documentation
  • EH Series Humidity Sensors – Specifications, Setup, and Documentation
  • NissyKutty
    NissyKutty
‎2018-09-06 10:02 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-21 04:48 PM
Users need specifications, setup details, and documentation for EH Series Humidity Sensors.
Field Devices
EH Series Humidity sensors
Lack of readily available technical details and installation guidance for EH Series sensors.
Refer to the following resources for complete specifications and installation instructions:
  • EH Series Specification Sheet
  • EH Series Humidity Sensor Installation and Operation Instructions
  • Legacy EH Series Installation Guide (for models with two dip switch sets)
Key Specifications:
  • Power Supply: +15 to 36 VDC or 24 VAC
  • Output Options (Field-selectable): 4–20 mA, 0–5 VDC, 0–10 VDC
  • Measurement Range: 0–100% RH
  • Accuracy: ±2% RH (model dependent)
  • Operating Temperature: -40°C to +70°C
Applications: HVAC systems, clean rooms, humidity-controlled environments.
Additional Notes:
  • Ensure correct dip switch settings for output signal selection.
  • For legacy models, use the “Old EH Series” guide.
  • Field Devices
Tags (5)
  • 14558
  • 4-20ma
  • ehr
  • JonGreen22
  • NissyKutty25
100% helpful (1/1)
