EBO system stopped syncing with Building Advisor Portal (BAP)
  • EBO system stopped syncing with Building Advisor Portal (BAP)
  • David_Purser
    David_Purser
Picard David_Purser Picard
‎2023-12-20 07:51 AM
EBO system was in sync with Building Advisor Portal and is now not.
EcoStruxure Building Operation, EcoStruxure Building Advisor
  • Building Operation Building Advisor Portal
  • Building Operation Automation Server
System ID changed and no longer matches in Building Advisor Portal.
  1. Check EBO Server Trace Log for nsp.pin.Cloud records and there should be one that shows "SystemId". Here is an example:
    1. 2023-11-19 12:37:30.437 [320] nsp.pin.Cloud.DspInterface Sending notification {"ProtocolVersion": "1.0", "NotificationType": "TimeSeries", "IotDeviceId": "urn:dev:ops:sebms-sbo-es-fb6b2834ba4749d89cdad333c12704a3", "SystemId": "4ba3db45-0235-7146-981a-c81dc08e39bf", "GeneratedAt": "2023-11-19T12:37:30.0437Z", "GeneratedBy": "SBO 3.2.4.22","Operation": "Update","TimeSeries": [{"TimeSeriesId": "d8e6b6fc-a472-4285-a56d-2d3e4a6915e1","Samples": [{"Timestamp": "2023-11-19T12:37:30.0437Z","Value": "Unknown [null]","Unit": "0x10001","Status": 20}]}]}
      2023-11-19 12:37:30.437 [320] nsp.pin.Cloud.DspInterfaceReal edgeAgent_sendMessage: {"ProtocolVersion": "1.0", "NotificationType": "TimeSeries", "IotDeviceId": "urn:dev:ops:sebms-sbo-es-fb6b2834ba4749d89cdad333c12704a3", "SystemId": "4ba3db45-0235-7146-981a-c81dc08e39bf", "GeneratedAt": "2023-11-19T12:37:30.0437Z", "GeneratedBy": "SBO 3.2.4.22","Operation": "Update","TimeSeries": [{"TimeSeriesId": "d8e6b6fc-a472-4285-a56d-2d3e4a6915e1","Samples": [{"Timestamp": "2023-11-19T12:37:30.0437Z","Value": "Unknown [null]","Unit": "0x10001","Status": 20}]}]} (retCode = 0)
  2. In Building Advisor Portal, check the BMS System Identifier to ensure it is the same and update as needed.
    2. In this case, d057cfba-9fc0-11e4-a62a-3417ebbed129 needed to be updated to 4ba3db45-0235-7146-981a-c81dc08e39bf
Labels (2)
  • EcoStruxure Building Advisor
  • DavidPurser23
100% helpful (3/3)
