EBO Support for UI16A CIO with FW 2.016 and HW C
  • EBO Support for UI16A CIO with FW 2.016 and HW C
  • RandyDavis
    RandyDavis
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2021-12-08 11:42 AM
on ‎2021-12-08 11:42 AM
  • Support for UI16A CIO with FW 2.016 and HW C
  • How is CIO FW 2.016 distributed?
EcoStruxure Building Operation I/O Module 16 Ch UI
Due to component changes in the UI16A CIO module, a new HW version C has been created. Consequently, a new firmware (FW) file has been created specifically for that new HW version, 2.016.
This FW version will be installed already at delivery from the factory for the new version of UI16A modules. For this new UI16A model, one cannot install older 2.015 firmware as it is not compatible. All the older modules can remain at the latest published CIO release 2.015.
The HW version which is printed on the product label is changed from B to C on the new UI16A version. The Hardware version can also be viewed in the module object through EBO. For all other modules, the HW version will stay at B.
  • MikaelKrantz21
