Duct sensors in room applications
  • Duct sensors in room applications
  • SESA150559
    SESA150559
‎2018-09-06 10:34 AM
If not considering the design of the sensor housing, can a duct sensor function also in a room application?
Duct style sensors
A specific application is requesting this type of setup
In general it is possible to use these sensors also for room applications. Maybe the time constant will be a little bit higher because of lower velocity which in room applications usually is irrelevant. For the SHD it might be that the sinter filter can absorb some radiant heat (if there is any).
  • Field Devices
  • 12754
