Drayton DC1100 / DC1400 controllers - Replacement battery.
  • Drayton DC1100 / DC1400 controllers - Replacement battery.
‎2018-09-06 11:14 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:39 AM
Replacement battery for the DC1100 / DC1400
Field Devices
  • DC1100
  • DC1400
  • Replacement Battery
Warning
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
Controller battery has failed.
The battery lifetime will vary over a very wide range depending on use and temperature so cannot easily be predicted, but about 5 years under normal conditions, would be a guide.
The battery in a DC1100 and a DC1400 is soldered to the underside of the CPU PCB. It is a 3.6V 150mAh NiMH battery. The factory part number is S2218121100 and the manufacturer’s part number is Varta 55615 603 940.
Please Note: - Good soldering skills will be needed to replace the battery.
The battery can be sourced from CPC Farnell
Varta 55615603940 details at CPC Farnell
  • Field Devices
Tags (3)
  • 11045
  • DavidChild19
  • replacement.
