Double feature values for Entitlements
  • Double feature values for Entitlements
  • PeterEdvik
    PeterEdvik
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2023-01-25 03:50 AM
Last Updated: Janeway PeterEdvik Janeway ‎2023-01-25 04:17 AM
Sometimes the availability count for license features are displayed as double the actual available count for Entitlements. The problem has no functional effect on the system other than that the visual indication of the feature count is wrong.
Issue seen in Entitlement View
- Features inside a License Product are doubled.
Issue seen in Server View.
-The issue can be seen temporarily during activation on the server line.
-The number of features inside the License Products available for activation under the server are doubled permanently.
Server line view after activation.
- After the license product has been activated the features on the server are shown correctly.
  • Building Operation Automation Server Premium (AS-P) Secure Boot
  • Building Operation Automation Server Bundled (AS-B) Scalable
AS-P Classic and AS-B Classic licenses are NOT affected. None of the Windows licenses are affected.
EBO releases affected:
  • All EBO versions up to and including 4.0.3.
    • The EBO systems that are already running licenses are Not affected.
    • Customers that for any reason reinstall an Entitlement in DA will be affected by the issue.
  • EBO 5.0.1
This issue is planed to be resolved in the following EBO versions:
  • EBO 4.0.4
  • EBO 5.0.2
  • JonasBrissman23
