Door Transactions defined in the Door Editor are not dialing back to the host
  • Door Transactions defined in the Door Editor are not dialing back to the host
‎2018-09-06 03:28 PM
I/NET
Only distribution group 1 messages will cause a dial tap to dial out. Keep this in mind if your system is configured to use the 7806x tap to report to a remote host.
Ensure that all doors and reader points use group 1 for messaging.
  • TAC INET
  • 1030
