Door Force Lock schedule configuration
  • Door Force Lock schedule configuration
  • sesa119747
    sesa119747
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:50 PM
Continuum Access Control
Enable the Door Force Lock Schedule attribute in the Door object.
This is a two part setting in order to successfully make Door Force Lock schedule work.
If you set up a point in the Door Force Lock Schedule on the options tab, You will need to check either Normal and/or Comm Fail
on the entry reader tab of the door editor in order to successfully work.
  • 2952
