Does the ECH-75010R (Echelon U-10 USB LON Network Adapter) come with the interface cable?
  • Does the ECH-75010R (Echelon U-10 USB LON Network Adapter) come with the interface cable?
  • sesa116868
    sesa116868
‎2018-09-06 01:11 PM
Does the ECH-75010R (Echelon U-10 USB Adapter) come with the interface cable?
Data sheet does not specify this information.
Data sheet does not specify what interface cable, if any is included with the U-10 adapter.
The Echelon U-10 LON Network adapter does not come with an interface cable.
As documented in the Echelon data sheet, the adapter only comes with a USB extension cable.
To use this adapter with the I/A Series LON controllers, the WPIA-CBL-1 is required.
  • TAC IA Series
  • 6373
