Does a Niagara R2 Enterprise Server work with dot-matrix printers connected via a USB port?
  • Does a Niagara R2 Enterprise Server work with dot-matrix printers connected via a USB port?
  • sesa116868
    sesa116868
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 11:04 AM
A Niagara R2 Enterprise Server's hardware was replaced.  The new hardware does not include a parallel (25-pin) RS-232 printer port for the existing dot-matrix printer which is used for printing out alarms.  It was connected with an adapter to a USB port instead.  Alarms will not print out.
Does the server support USB-connected printers?
Niagara R2
pc hardware replacement
Niagara R2 does not support USB-connected printers.
The dot-matrix printer needs a connection via a RS-232 serial port or a standard (25-pin) parallel port.
  • TAC IA Series
  • 11256
