Displaying Correct Regional Units in Webstation
  • Displaying Correct Regional Units in Webstation
  • HenrikTarpgaard
    HenrikTarpgaard
  • Derrick_Ratliff
    Derrick_Ratliff
  • Benji
    Benji
‎2018-09-06 02:53 PM
Metric vs. Imperial Units as displayed Using Webstation Regional Settings
Any device, will by default, show configured units. Regional settings must be applied to normalize all devices.
  • Webstation
  • TGML Graphics
  • SNVT values
Incorrect Units will appear in webstation if webstation regional settings are not configured correctly.
  1. Log into Webstation
  2. Select Settings > Change Regional Settings
  3. Select the desired Language
  4. Select the desired Measurement system
  5. Click Ok
NOTE: Settings are preserved via a cookie stored on the local PC. Any time cookies are deleted this will return to its default setting.
Tags (8)
  • 11612
  • celsius
  • degrees
  • different
  • fahrenheit
  • PeterLarsen24
  • temperature
  • workstation
100% helpful (3/3)
