Display local server time PE Script example
  • Display local server time PE Script example
  • Dave_Shore
    Dave_Shore
  • DavidChild
    DavidChild
  • Carl_Slack
    Carl_Slack
‎2018-09-06 10:14 AM
Last Updated: Sisko DavidChild Sisko ‎2020-05-28 03:26 AM
Provide a solution for displaying local server time
  • Building Operation Automation Server
Request to display local server time
Example code below can be inserted into a PE Script to allow display of local server time from within the workstation. By converting the time into a string the display of the information is not affected by any localization that is attempted by the client.
datetime output ServerTime, ClientDisplayTime
string output DisplayTimeString, DisplayTimeString2
String ampm
numeric h1, h2
numeric Adjustment
' Time Adjustment: UTC Offset, DayLight Savings Time
Adjustment = 4*3600
ServerTime = Time
'Set the desired Client Display Time
ClientDisplayTime = ServerTime + Adjustment
'Set String to ServerTime
print ServerTime to DisplayTimeString
h1 = TimePiece(hour, ServerTime)
if h1 = 24 then h1 = 12
if h1 > 12 then
 h2 = h1-12
 ampm = "PM"
else
 h2 = h1
 ampm = "AM"
Endif
print TimePiece(month, ServerTime);"/" ;~
      TimePiece(dayofmonth, ServerTime);"/";~
      TimePiece(year, ServerTime),~
      h2;":"; ~
      TimePiece(minute, ServerTime);":";~
      TimePiece(second, ServerTime), ampm to DisplayTimeString2
Tags (2)
  • 13794
  • DavidShore20
