Display a PDF file in a Niagara G3/AX graphic
  • Display a PDF file in a Niagara G3/AX graphic
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-11 01:32 PM
Using 3.7.106 and want to display a PDF file on a Niagara G3 / AX graphic. It's been done in the past but with "Default Web Profile" "Applet Reload on Hyperlink" set to "False" the PDF does not display.
Is there a way to do it without setting the "Applet Reload on Hyperlink" to "True"?
TAC IA Series
Niagara G3 / AX revision 3.7.106 and higher
More secure changes made to G3 / AX
Instead of creating a hyperlink button with hyperlink:
file:^blahblah.pdf
Use:
http://137.19.60.55/ord?file:^blahblah.pdf
This opened the PDF in the browser (it left the default web profile but the back button returned to it).
  • TAC IA Series
Tags (2)
  • 16976
  • graphics
