Disable "Dynamic DNS" in Device Administrator
  • Disable "Dynamic DNS" in Device Administrator
  • PeterEdvik
    PeterEdvik
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2020-09-11 04:54 AM
on ‎2020-09-11 04:54 AM
"Ethernet 1 Configuration" of a SmartX Server in the Device Administrator for EBO version 3.2.1 or higher shows "Dynamic DNS" as enabled and grayed out. Is it possible to disable "Dynamic DNS"?
Building Operation Automation Server Premium version 3.2.1 or higher
The Dynamic DNS service procedure supports the assignment of dynamic IP addresses to a particular domain. A comparison with the internet provider's DNS databases takes place automatically. The Dynamic DNS automatically ensures that changes to the IP address are detected and DNS entries are updated accordingly.
In EBO version 3.2.1 or higher it will not be possible to disable Dynamic DNS, it will always be enabled.
  • JonasBrissman20
80% helpful (4/5)
