Different override types on a 7780 Lighting Controller
  • Different override types on a 7780 Lighting Controller
‎2018-09-06 03:29 PM
What are the different override types on a 7780 Lighting Controller?
Different override types behave differently.
Permanent means the override will continue indefinitely until:
  • the button is pressed,
  • the switch is moved,
  • or the next time schedule off time happens.
Timed means the override will run for a specified number of minutes (0-120).
  • TAC INET
  • 951
