Different Forta versions.
  • Different Forta versions.
  • SESA150559
    SESA150559
‎2018-09-06 12:52 PM
There are different versions of TAC Forta actuators available on the global market.
Forta actuators on the global market.
  • M400
  • M400A
  • M800
  • M800A
  • M1500
  • M1500A
There are different types of Fortas available.
The "A" version of the Forta actuators are designed to be used on the US market. There are several differences between the "A" series and the regular type, but the key ones are:
  • UL approval
  • Electrical connections designed to conform to US standards
  • The VB version is equipped with a short yoke to fit directly on the VB series of valves used on the US market.
  • Field Devices
  • 6981
