Differences in packing material used on V241/V341 connection kits
  • Differences in packing material used on V241/V341 connection kits
  • SESA150559
    SESA150559
‎2018-09-06 12:30 PM
There are 2 different packing types available for ordering when choosing connections for the V241/V341
V241
V341
There is a difference in material used in the gaskets included with the connection packages.
The "Packing, std" is a standard type gasket.
"Packing, spec" is intended to be used in primary circuit district heating applications. Material in gasket is PTFE.
  • Field Devices
  • 7641
