Difference in SmartStruxure Backplanes for Power Supply and Automation Server Modules
  • Difference in SmartStruxure Backplanes for Power Supply and Automation Server Modules
‎2018-09-11 01:48 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:38 AM
In rare occurrences, technicians may remove the bottom terminal from the AS or I/O Baseplate so that a power supply can fit. The backplanes inside the baseplates are not all the same and this will not work.
Visually determine which baseplate is for each module.
  • SmartStruxure Power Supply
  • SmartStruxure Automation Server
  • SmartStruxure I/O module
Incorrect baseplate will not work on the SmartStruxure modules.
See picture for representation of Power Supply backplane, the other configuration is for Automation Server (and I/O modules).
For more detailed information please see the Hardware Reference Guide.
  • 17101
