Difference between valves V211 and V211T
  • Difference between valves V211 and V211T
  • SESA150559
    SESA150559
‎2018-09-06 12:49 PM
Please define the difference between the V211 and V211T
V211
V211T
There are 2 different valves with similar characteristics, what differences are there, and why should I choose one or the other?
V211 is equipped with flanged connections, while the V211T has internal threaded connections.
  • Field Devices
  • 7079
100% helpful (1/1)
