Difference between the TTS-SD-LCD and the TTS-SD-LCD-4 smart sensors.
  • Difference between the TTS-SD-LCD and the TTS-SD-LCD-4 smart sensors.
  • AbeMeran
    AbeMeran
‎2018-09-06 10:51 AM
What is the difference between the TTS-SD-LCD and the TTS-SD-LCD-4 smart sensors?
Field device sensors
Documentation
The difference is in the number of buttons, the TTS-SD-LCD has six buttons while the TTS-SD-LCD-4 has only four.
  • 11889
