Device Discovery in PCT
  • Device Discovery in PCT
  • RandyDavis
    RandyDavis
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2021-04-02 10:20 AM
Last Updated: Guinan RandyDavis Guinan ‎2021-04-02 10:21 AM
Want to add the RP-C devices to the PCT project by using Device Discovery
  • Building Operation Project Configuration Tool (PCT)
  • Building Operation Workstation
All communication from the SmartX Servers is blocked when using the PCT.
The Device Discovery command does not work in the PCT.  This can be done after the project has been deployed.
Labels (2)
  • Project Configuration Tool
  • MikaelKrantz21
