Device Administrator can't export server list or the root certificate when FIPS is enabled
  • Device Administrator can't export server list or the root certificate when FIPS is enabled
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2025-08-07 03:55 PM
on ‎2025-08-07 03:55 PM
After enabling Federal Information Processing Standard (FIPS) Compliance in Windows Security settings, the following issues are observed in Device Administrator:
  • Cannot export server list
    Error: "The server list could not be exported."
    Reason: The file could not be encrypted.
    "The server list could not be exported." Reason: The file could not be encrypted"The server list could not be exported." Reason: The file could not be encrypted
  • Cannot export root certificate with private key
    Error: "Export of CA root certificate failed: Could not encrypt the certificate."
Export of CA root certificate failed:  Could not encrypt the certificate.Export of CA root certificate failed: Could not encrypt the certificate.
  • Building Operation Device Administrator
  • FIPS compliance
Device Administrator is not FIPS compliant. Enabling FIPS mode in Windows enforces the use of FIPS-compliant cryptographic algorithms across all applications. This can lead to failures in applications that do not support these standards.
To work around this issue:
  • Temporarily disable FIPS on the affected PC
    or
  • Use another PC where FIPS is not enabled to perform the export operations.
  • MahmoudSayed25
