[Dev File] Xenta 5/7/9xx Modbus RTU Integration to Schneider Electric PM710 Power Meter
  • [Dev File] Xenta 5/7/9xx Modbus RTU Integration to Schneider Electric PM710 Power Meter
  • PeterLarsen
    PeterLarsen
  • sesa115370
    sesa115370
‎2018-09-10 11:40 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 05:17 PM
This article provides guidance on integrating the Schneider Electric PM710 Power Meter with the following Xenta controllers using Modbus RTU:
  • Xenta 511, 527, 555, 701, 711, 721 (Firmware version 5.1.5 and above)
  • Xenta 731, 913 (All versions)
TAC Vista
  • XBuilder
  • Schneider Electric PM710 Power Meter
  • Xenta 5xx / 7xx / 9xx series controllers
Integration is required when PM710 Power Meters are used in systems managed by Xenta controllers via Modbus RTU. To support this, Product Support has developed a device template to assist with configuration. This template is intended as a starting point and may require customization to meet specific project needs. It is not a comprehensive points list.
Note: For assistance with template customization or troubleshooting, contact your local Schneider Electric Support team.
To integrate the PM710 Power Meter with Xenta controllers using XBuilder, follow these steps:
  1. Download and Extract the Device Template
    • Download the .zip file containing the .dev file from the link below.
    • Extract the .dev file to a convenient location on your hard drive.
  2. Add the Device in XBuilder
    • Open your XBuilder project.
    • Right-click on the Modbus Master device.
    • Select Add Device.
    • Browse to the extracted .dev file and click Open.
  3. Configure the Device
    • Rename the newly added device to ensure it has a unique name within the Modbus Master network.
    • Adjust the device template as needed to match your specific integration requirements.
Downloads
  • Modbus Device Template – PM710 (.zip)
  • PM710 User Manual (PDF)
[Modbus Ext]PM710.zip
Tags (2)
  • 7923
  • PeterLarsen25
