Deny Entry Tenant when entering new badges after restoring from a system crash
  • Deny Entry Tenant when entering new badges after restoring from a system crash
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 02:08 PM
Deny Entry Tenant when entering new badges after restoring from a system crash on a New Host workstation
I/NET
Devices in the field may still be looking for the former workstation due to a system setting such as automatic DPU restore.
  1. Connect to the controller
  2. Select Edit>Controller>Station Save
  3. Select Edit>Controller>Station Restore
  4. Select The DPU option
  5. Select the affected DPU and click okay
  6. Try a badge to verify results
This error should only occur when badges are added immediately after a system recovery.  If the issue continues, contact product support.
  • TAC INET
  • 4587
