Dell Optiplex GX 620 and GX 520: When logging into Vista the PC reboots.
  • Dell Optiplex GX 620 and GX 520: When logging into Vista the PC reboots.
‎2018-09-07 01:16 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:38 AM
  • Dell Optiplex GX 520
On some Dell computers, there is a problem with the graphics hardware acceleration.
Adjust these setting with the following instructions:
  1. Right click on the desktop
  2. Select Properties
  3. Click on the Settings Tab
  4. Click the Advanced Button
  5. Select the Troubleshoot Tab
  6. Adjust the slide bar of the Hardware Acceleration down from Full two or three bars
  7. Click OK
  8. Click OK Again
Now you should be able to open Vista without the PC Rebooting.
This problem is experienced on Dell Optiplex GX 620 (TPI C-88-1-F-97) and Dell Optiplex GX 520 (TPI C-88-1-F-95)
  • 2482
