Deleting doors in the access control editor
  • Deleting doors in the access control editor
  • sesa139513
    sesa139513
  • sesa145087_brid
    sesa145087_brid
‎2018-09-06 03:22 PM
I/NET Site with Access Control
When deleting a door from a 7791 DPI, 7793 MCI or a 7798 I/Site LAN, make sure to delete the door Parameters before deleting the door (DO) point. Deleting the door (DO) point without previously deleting the door Parameters may cause unpredictable system performance.
If the point has already been deleted first, the best way is to:
  1. Re-add the point again
  2. Save it in the NetCon
  3. Follow the correct sequence. Then it will work fine.
  • TAC INET
  • 1271
