Deleting a Group from the System Plug-in
  • Deleting a Group from the System Plug-in
‎2018-09-06 03:10 PM
TAC Vista System Plugin
After adding a controller to the Vista database, the System Plug-in automatically creates a new Group
If you move the new controller to a different Group, make sure the controller you added is not still selected when you try to delete the old group. By default, both the controller you moved and the group you moved it from will be selected. Hitting the delete key will delete both.
  • 1798
