Defining a device name for each Network 8000 Microflo II controller is possible when it is configured under a GCM. When defining it via a Niagara R2 UNC station, using the ASD driv...
  • Defining a device name for each Network 8000 Microflo II controller is possible when it is configured under a GCM. When defin...
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:35 PM
Defining a device name for each Network 8000 Microflo II controller is possible when it is configured under a GCM.  When defining it via a Niagara R2 UNC station, using the ASD driver, it is not possible.
  • Niagara R2 UNC station
  • Network 8000 Microflo II controller
Not a supported feature in the ASD driver.
Due to the maturity of the Microflo II product this is a feature that will not be incorporated into the ASD driver.
  • TAC IA Series
  • 3540
