Data Sync Service will not import controllers correctly if Serial Number field is selected
  • Data Sync Service will not import controllers correctly if Serial Number field is selected
  • PeterEdvik
    PeterEdvik
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2021-09-23 10:07 PM
Last Updated: Janeway PeterEdvik Janeway ‎2021-09-23 10:11 PM
Importing Security Expert controllers' serial numbers will break the import process and result in only creating default templates for the controllers.
EcoStruxure Security Expert
  • Security Expert Server
  • Security Expert Data Sync Service
Security Expert controllers' serial numbers are displayed in hexadecimal. However, in the SQL database they are  stored as decimal values. So the Data Sync Service is expecting a decimal integer and is instead receiving a string.
Convert the serial numbers in the .CSV import file from hexadecimal to decimal. This can be done in excel using the  "HEX2DEC" function. E.g. if the controller serial number is "ABCDEF12", it must be converted to decimal value "2882400018" before importing to Security Expert.
  • EcoStruxure Security Expert
  • MahmoudSayed21
