Data Display Constraint in HVAC Optimization Module – BA Portal
  • Data Display Constraint in HVAC Optimization Module – BA Portal
  • Katha
    Katha
Lt. Commander Katha Lt. Commander
‎2025-10-07 10:25 PM
on ‎2025-10-07 10:25 PM
The HVAC Optimization module in the Building Advisor (BA) portal is currently displaying data that is two months behind the current date.
Snapshot:
The image below illustrates the data available within the HVAC Optimization module as of October.
  • EcoStruxure Building Advisor
  • HVAC Optimization Module
This does not represent a defect in data collection or in the functionality of the Building Advisor Portal
The limited data display is intentional and aligns with the system’s design principles. Energy providers often apply retroactive adjustments to consumption records, and interim placeholder values can be unreliable. By excluding these, the system ensures data integrity and accuracy.
Additional Notes:
  • This behavior is expected and documented.
  • No action is required unless data is missing beyond the expected two-month delay.
Labels (2)
  • KatharineVasquez25
