Dashboard dynamic search widget cannot find graphics on child servers
  • Dashboard dynamic search widget cannot find graphics on child servers
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2023-09-21 04:23 PM
Search widget graphics can't find graphic pages created under child servers.
Building Operation Webstation
Currently, in EBO 2023, the dynamic search widget will only find graphic pages created on the server the user is logged into on WebStation. The dashboard search widget is not related to the native EBO search object and cannot search child servers.
EBO 2024 (V6) or higher:
From 6.0.1 it is possible to include TGML widgets from sub servers (all servers must have EBO version 6.0.1). Note that this functionality is only supported when you use HTTPS as the protocol between the servers, which is the default protocol in 6.0.1.
EBO 2023 (V5) or lower:
If graphic pages are located under child servers, they need to be added to the dashboard manually.  Refer to: Adding a Graphic to a Dashboard
  • MahmoudSayed23
