Damper actuator with on/off or 3-point control
  • Damper actuator with on/off or 3-point control
  • SESA150559
    SESA150559
‎2018-09-06 10:57 AM
Which damper actuators are available with 3-point control?
8751001000 Actuator Damper MD5B-230
8751003000 Actuator Damper MD5B-230-S
8751005000 Actuator Damper MD5B-24
8751007000 Actuator Damper MD5B-24-S
8751011000 Actuator Damper MD10B- 230
8751015000 Actuator Damper MD10B-24
8751021000 Actuator Damper MD20B- 230
8751025000 Actuator Damper MD20B-24
8751035000 Actuator Damper MD40B-24
Both modulating control (0-10V) and On/Off 3-point control damper actuators are available.
All MDX(X)B damper actuators are On/Off or 3-point control.
  • Field Devices
  • 11528
