DWiz.exe presents The application file could not be found! error
  • DWiz.exe presents The application file could not be found! error
  • David_Purser
    David_Purser
Picard David_Purser Picard
‎2022-11-15 01:30 PM
on ‎2022-11-15 01:30 PM
Using Download Wizard 32 with Application set to Clear Memory, one will get an error that "The application file could not be found!
  • Building Operation Workstation
  • Xenta Programmable Controller
EBO Workstation does not include the Lonm<Model Number>.MTA file.
There are two solutions:
  1. Create a minimal MTA file for the device type.
    1. Open Menta Editor
    2. Change the device specification for the appropriate Xenta Type.
    3. Add one PVR block
    4. Save the file.
    5. In DWiz, change Application selection to Download New and Browse in the new file.
  2. Perform the steps again with the expected files in the same folder as DWiz.
    1. Download the attached Lonm.zip (derived from Menta 5.1.9)
    2. Extract the files in the zip to the same Workstation folder where Dwiz.exe is found. Sample Location: "C:\Program Files (x86)\Schneider Electric EcoStruxure\Building Operation 3.2\WorkStation\DWiz.exe"
    3. Perform the download again with the same Clear Memory selection under the Application section.
Lonm.zip
  • DavidPurser22
