DUI Expander Objects for BACnet Devices in WorkPlace Tech
  • DUI Expander Objects for BACnet Devices in WorkPlace Tech
‎2018-09-07 06:41 AM
Last Updated: Crewman ContentModerator ‎2025-10-15 03:37 AM
Where are the DUI expander objects for the MNB-300 and MNB-1000 controllers in Workplace Tech?
TAC IA Series
  • I/A Series WorkPlace Tech version 5.1 through 5.9.4
  • I/A Series WorkPlace Tech version 5.10.0 till current
The standard stencils do not include an object for Momentary SS or a DUI multiplexer.
The I/A Series BACnet controllers do not currently support the DUI object directly within the MNB-300 or MNB-1000. An application performing the same basic function was created and factory tested. This application was created as a custom object named "DUI_App".
For support of these objects in Workplace Tech 5.1 until 5.9.4, log into The Exchange Download Center and download the file Application Objects_rev1.zip. There is also a detailed DUI_Application_Documentation_rev1.pdf that describes the operation of the "DUI_App".
For support of these objects in Workplace Tech 5.10.0 until further notice, log into The Exchange Download Center and download the file Application Objects_rev2.zip. There is also a detailed DUI_Application_Documentation_rev2.pdf that describes the operation of the "DUI_App".
Note: VAV box controllers do not have DUI expander objects available.
See TB06-02 for additional details.
  • TAC IA Series
Tags (4)
  • 4648
  • DUI
  • RandyDavis21
  • vssx
100% helpful (2/2)
