DC1100 / DC1400 Display corruption.
  • DC1100 / DC1400 Display corruption.
  • DavidChild
    DavidChild
‎2018-09-06 02:16 PM
Last Updated: Sisko DavidChild Sisko ‎2020-12-15 01:15 AM
DC1100 / DC1400 Displays two horizontal black lines when powered up.
Field Device
DC1100 / DC1400 Discrete Controller.
Cold Start has not been performed.
Cold Start has been performed incorrectly.
Mains borne corruption has affected processor.
Carry out Cold Start:
  1. Isolate Controller power supply.
  2. Press and hold down "Enter" and "Exit" buttons.
  3. Keep "Enter" and " Exit" buttons depressed while restoring power.
  4. Display should show "Self Test" and "Initiating System Variables"
  5. Release "Enter" and "Exit" buttons.
Controller may then be programmed in accordance with Data Sheet instructions.
Or, if the controller is non-recoverable, the DC1100 and DC1400 units are now obsolete. However, there are several 3rd party companies offering refurbished units, these can be found by using a browser and searching e.g. DC1100 repairs.
  • Field Devices
Tags (2)
  • 4344
  • DavidChild20
100% helpful (1/1)
