Customize the logo/branding in a Xenta 7XX
  • Customize the logo/branding in a Xenta 7XX
  • sesa150555
    sesa150555
‎2018-09-06 02:32 PM
How can I change the logo in a Xenta 7XX so it shows my company instead of TAC/Schneider Electric?
Xenta 701, 711, 721, 731
Image files are loaded with the download of a system program and default to TAC or Schneider Electric branding depending on the version. To customize them to another corporation's logo, the files must be manually edited through FTP.
  1. Use ftp to get the files below from the Xenta 7xx.
  2. Edit the files with the new logo and rewrite them to the original location in the Xenta7xx.
  3. Power down/Power up the Xenta 7xx.
Logo files:
Directory www/index
Directory www/images
  • 731splash.jpg (change if Xenta 731)
  • 721splash.jpg (change if Xenta 721)
  • 711splash.jpg (change if Xenta 711)
  • 701splash.jpg (change if Xenta 701)
Note that this will be reset back to default if a new system program (firmware) is loaded.
  • 3673
