Custom Audio Files for I/NET Seven AMT
  • Custom Audio Files for I/NET Seven AMT
  • Tom_Poovey
    Tom_Poovey
‎2018-09-10 02:12 AM
Customize the alarms sounds that are set in the AMT configuration editor.
Any I/NET Seven Version
Change the default audio alerts for each routine, priority, or critical alarm.
  1. From the task bar, select the Alarms, Messages & Transactions window
  2. Navigate on the menu bar to Edit > Configuration
  3. Under Audible alarms, browse to the desired sound file for each priority.
  4. If desired, custom alarm sounds are available for download here, (This is a ZIP) file.
  • TAC INET
Custom AMT Audio.ZIP
  • 6196
