Creating a report of visitors using the Visitor Management System
  • Creating a report of visitors using the Visitor Management System
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2022-12-22 07:40 PM
on ‎2022-12-22 07:40 PM
When configuring the in-built Visitor Management System (VMS) there is no report mechanism under the Visitor tab to show visitor access.
EcoStruxure Security Expert
  • Security Expert Client
  • Visitor Management System
Reports for visitors are part of the list of the Report types under the more general User reports
Visitor reports for visitors using the in-built VMS can be generated with a User Report by selecting one of the following Report Type options:
  • All current visitors
  • All overdue visitors
  • All visitors by date
Visitor user report setupVisitor user report setup
This can then be further configured to your requirements by editing the report filter. Launch the event report view in a new window by pressing the Edit in report view button. The report can be run and filters can then be configured as required and saved as the default report filter.
  • EcoStruxure Security Expert
Tags (3)
  • AdamSteele22
  • HernanUruena23
  • HernanUruena24
100% helpful (1/1)
