Create reports from or in an Automation Server
  • Create reports from or in an Automation Server
  • Benji
    Benji
  • sesa150561
    sesa150561
‎2018-09-06 09:21 AM
  • Want to create reports from an AS
  • Automation Server
To be able to create reports you will have to have an ES and a reportserver installed. However you can export a trendlog to XML or CSV and create you own report with a thirdparty software.
Install an ES and a reportserver or export a trendlog to CSV or XML and use a thirdpart software to create your report.
  • 16964
100% helpful (1/1)
