Copied SNVT names in Function Block Program don't update when commissioned in LNS
  • Copied SNVT names in Function Block Program don't update when commissioned in LNS
  • sesa139513
    sesa139513
‎2018-09-06 01:08 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-15 07:09 AM
If a Standard Network Variable Types (SNVT) in a Functional Block program is copied and renamed, when commissioning the local node with an LNS tool the node, the copied SNVT keeps its original copied name.
StruxureWare Building Operation site
The XIF file in the device is not getting updated when the signal name changes. An LNS management tool will upload this XIF file and use it to see the values.
This has been reported as bug in software and will be resolved in an upcoming release.
  • 6474
