Converting Continuum b3/i2 Tristate outputs to EBO Multistate outputs
  • Converting Continuum b3/i2 Tristate outputs to EBO Multistate outputs
  • AbeMeran
    AbeMeran
  • RandyDavis
    RandyDavis
Captain AbeMeran Captain
‎2022-04-04 06:34 AM
on ‎2022-04-04 06:34 AM
When converting b3/i2 Tristate outputs to EBO Multistate, care must be taken to convert to the appropriate Multistate OR Multistate Pulsed output type
  • Continuum b3850 Controller
  • Continuum i2850 Controller
Continuum Tristate outputs controlling dampers need to be converted to EBO Multistate pulsed
The tool will convert to Multistate or Multistate Pulsed based on the "Format" property of the Continuum Tristate output.
To have the tool convert to Multistate Pulsed, change the 'Format" property of the Continuum output From $### to #.# or another applicable format that does NOT include the "$"
This can be done in the dump file that is to be used for the conversion.
Tags (5)
  • AbeMeran22
  • damper
  • multistate
  • output
  • tristate
