Controlling AC relays from analog outputs on the motherboard or expansion board of the 7718 PCU
  • Controlling AC relays from analog outputs on the motherboard or expansion board of the 7718 PCU
‎2018-09-06 11:12 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:37 AM
I/NET Site
The outputs from these locations are DC. This may cause the AC relays to “chatter” or not work at all. It is recommended to use a P8UI8DO at the expansion board or place DC powered, form “C” contacts, pilot relays on the outputs of the PCU. Refer to TCON106 for more details.
  • TAC INET
  • 1118
