Continuum can not store a database of biometric data and authenticate based on it without needing an access card
  • Continuum can not store a database of biometric data and authenticate based on it without needing an access card
‎2018-09-10 03:44 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:37 AM
Can Continuum store a database of biometric data and authenticate based on it without needing an access card?
CyberStation
Access Controllers
Biometrics
Desire to use fingerprint only authentication (no card required) with Continuum.
Continuum can not store biometric data and authenticate based on it alone. However, Continuum can be integrated with biometrics in several ways. The two most common are:
  1. Using smart cards to store the biometric templates. When the card is presented to the biometric reader it transfers the biometric data to the reader and the person's biometric is validated against that stored on the card. Then the card Wiegand data can be sent to the controller for authentication and entry or denial.
  2. Using the Security COE Continuum Bioscrypt Integration. Refer to the Continuum - Bioscrypt Integration data sheet.
  • 6484
